Maintenance and Repair
Check Data Integrity
 VerifyStore --id=1 --includeIndexes=true
 VerifyStores --includeIndexes=false
Maintain all FDB Files
 MaintainFileSystemDatabases
 CompactMasterDatabase
  RebuildSelectedStoreIndexes
